Yeah, thinking my volts are a bit high but I guess it's because I have good cooling...
What is your cooling? my AIO is on its way out, time for a new one.
noctua nh u12s, I did the blobs of paste over the two dies and that knocked 3c off from a max of 63c running R15.
Where are people getting £15 and 'a few quid more' price difference between the 3600 and 3600x? The price difference is £35-40.
Ah right, thanks for the explanation.there was a generic ebay code. which meant you got 10% or 15% off everything on ebay.
so 10% off something which is £220 means a £22 discount which means it's now £198 bringing it closer to the £189 price of the 3600.
Do the Ryzen 3000 chips come with thermal paste or do you need to buy that separately?
they come with a cooler which has thermal paste already applied to the cooler. so if you are using stock cooling you don't need any. saying that most third party coolers come with thermal paste too. my last 3 coolers have all came with paste.
Still no ABBA for the MSI Carbon..
Buy Asus, expensive yes, but you get better quality.
Is that Sarcasm? It's hard to tell sometimes.
MSI are the worst for BIOS updates. My Intel MSI hasn't had an updated BIOS in 2 years and the motherboard is only 3 years old. So they supported it for 1 year. It was there most expensive motherboard too at the time.
My other MSI AMD mobo has only ever had 1 update for 3rd gen ryzen whereas the asus of same age has had at least 4.
I wouldn't buy MSI again based off this experience.
