Been discussed before. Netflix original app streams HDR/Dolby Vision/etc. Sky seems to 'only' be up to 4k and with that there appears to be some compression too.is it just me or is the picture quality of netflix on the sky q box poor - i done a test netflix via the sky q box then netflix via the LG TV netflix app, the tv netflix looks much better.
Check your software is up to date. It should have been fixed in the latest release.*tumbleweed*
Still seeing the same behaviour. I guess no one else is or this thread would be a little more active
Did you also check the software in the main box as well as a mismatch could cause this behaviour.Had an issue last few days with my mini box, when clicking delete on something I'd watched it gets deleted off the main box but the UI is stuck on the screen on the mini and you can't quit it without either rebooting the mini box or leaving it 4 hours to go into sleep mode.
Did the software update even though it was up to date this morning see if that makes a difference with it.
Compression is bad at times, especially on broadcast. Try downloads via on demand as the bitrate seems to be higher.Quick question, I got sky movies added to my package the other day for first time.
The qaulity seems fairly bad compared to normal sky hd tv shows. The 4k movies have a lot of artifacts and distortion in the dark areas.
Is this normal?
Thanks for the heads up. Are software updates not done automatically?Check your software is up to date. It should have been fixed in the latest release.
They should be but boxes can sometimes miss it. Press Home, down to settings then system details, software version. There’s an option on the right side for a download. I’m not sure if the current correct version, I’m not customer facing any more.Thanks for the heads up. Are software updates not done automatically?
Already done, thank you though. Update applied just need to wait until tomorrow to see if it is fixedThey should be but boxes can sometimes miss it. Press Home, down to settings then system details, software version. There’s an option on the right side for a download. I’m not sure if the current correct version, I’m not customer facing any more.
How are the Q mini boxes over wifi? Haven't got an Ethernet point in the room atm.
Is this normal?
Mine works flawlessly
We cancelled the movies. Invested in a 4k player instead and now swap 4k movies on avforums classifieds. It made sense, since I've got a huge oled, why settle for sub par media quality on something I've spent so much money on?Quick question, I got sky movies added to my package the other day for first time.
Is this normal?
