- 12 May 2011
- Southampton
Today I picked up Midtown Madness. I don't get any CD music on my modern Windows 7 PC, I'm trying to decide if I can be bothered to swap out for an older PC or not.
Yeah I've had that set up before with my Soundblaster AWE32 I just don't know if I can be bothered to set it all up again or just play it without the music on Windows 7
Edit - CD audio should "send" via the PCI interface on XP and later though anyway, I think it was just a W98 and earlier thing needing the cable.
I thought it was a chipset thing that allowed audio to be passed down the IDE cable
I believe it's related to the driver model used. Back in 2001 I had a PC running Windows ME, and when I upgraded to a SB Audigy, it was necessary to use either an analog or spdif cable. Turns out it was because the Audigy used VXD drivers, which don't support the audio passthrough that WDM does. I pretty much confirmed this at a later date when trying the kxproject drivers on the same card - they are WDM, and CD audio worked fine without a cable.
Of course if you're using 98SE or ME for retro gaming then VXD is the way to go, as the WDM implementation on those operating systems introduces quite a lot of latency at the mixer apparently.
Good game thatCurrently on Wind Waker for the Gamecube. Its stood the test of time thanks to its stunning art style
Yay for this particular era of gaming.it counts!Age of Empires 2 HD if that counts. Still and great game with a huge community.
