- 2 Oct 2007
- Oxfordshire
I know it ain't quiet, but I game with headphones anyway
I got a confirmation email about my registration but nothing else.
In trying to figure out if my card is scoring good, pointless using 3dmark hof, what did you get?
What, call yourself an overclocker!I have never water cooked my GPUPretty sure that invalidates the warranty!
I have actually water cooked two gtx 470s. Pump didn't come on (thank you aquero) and fried two cards as no waterflow![]()
@0121danwilliams84
I just set to 2050 @ 09.50v and lock with L key 100% power 1200+ on memory saved as 3d profile
also saved defaults as the 2d profile so it down clocks properly
Just see how high a clock u can maintain stable with lower voltages
Well, you have a better chip than I do. Or at least, it requires lower voltage.
I have been messing around with undervolting.
I am using the OC scanner curve and flattening out the point at my chosen voltage.
I am sure I could get better results with a manual overclock, but I can't be bothered testing and crashing.
1.040v gets me 2070MHz sustained under heavy load and drops about 2-3 degrees off max temp (from initial testing)
I also lose about 30Mhz. But swings and roundabouts!
Memory kept at a nice round number +500 for 15000 overall.
Keeps temps just under 55c.
Also, it doesn't hit the power limit in any of the games I tested anymore.
I was hitting the power limit even with the 380W Galax Bios!
Got the gigabyte auros extreme installed this morning before parkrun, on default fan curve it settled at 1935mhz, but at 52c CAM was telling me the fans weren't even on!
Guessing that's down to good case airflow. That's water cooled temps territory!
What is a good sauce to go with a cooked 2080ti? And any recommendations for a white wine?
I fancy a change from the usual tonight.
Anybody have a 2080 ti FE and how hot does it get mine was hitting 87 degrees non overclocked put fans at 100 percent hits 80 degrees hotter than my zotac mini 1080 ti i used to have i will never buy a FE graphics card ever again.
