- 21 Sep 2018
Sent the b450 back and all's well with the x570.
Right any links and tips for standard use? XMP or tuning utilities/must haves?
You can leave everything at Default Optimized in BIOS (Stock) and just use XMP/DOCP for the RAM. Depending on the RAM, you may have to add a bit of voltage. My GSkill Ripjaws V 3200 CL16 M-die are running at DOCP 3200 CL16 but raised the speed up to 3333 CL16 with 1.36v. If you cannot make it run at DOCP, then use the DRAM Calculator.
For monitoring, use only HWINFO64 or Ryzen Master. I use the former only.
The chipset driver i downloaded directly from AMD site not the board manufacturer.
https://www.amd.com/en/support/chipsets/amd-socket-am4/x570
