Do all the same X56xx overclock the same? Are they essentially the same once clocked?
Your better of playi g lottery with 5 x x5650 at £10 each rather than buy 1 x x5690 for £60-£70. The
The x5690 is not worth 6x more for extra 200mhz possible oc.
i want to buy an used Xeon X5675 and have currently an i7-950 on a X58-UD5 Rev1.0 (see signature). Do you know since which bios my preferred Xeon runs on this board?
Hi guys,
Best regards
MaXx
Thanx for ya quick replies. The X5675 is stable @ 4.5 GHz, can I achieve this on the X5650 too? I live in germany, the best pricing is ~13€ (X5650) and/or 35€ (X5675), the 22 bucks more I would like to spend, if the clocks are better.
Edit: Big question... my PSU has 750W, ist this enough for the upgrade?
Update: I've recently buyed a used and very cheap X5670 @ eBay.
Three Questions:
1) Are the OC-important setting options similar to my old i7-950?
2) Has the Xeon "newer" or "alternative" features to disable resp. enable for fail-safe OC?
3) Can I achieve 4,0-4,3 GHz without voltage-adjustments or is there SAFE value?
Requesting your suggestions! I'm surely not a PRO, but my old i7-950 @ 4,025Ghz was self-OCed prime-stable and runs 15/7 w/o BSODs.
Best regards,
MaXx
Hi,
@AMDPower: No I don't want to use my old settings, my question was if the "options" to change (alter, enable, disable etc.), are the same like at an i7-xxx.
@all: 4 Ghz are really nice for me personally. I hope my CPU is a good sample, so I can easily reach 4Ghz w/o overvoltage. My board is a Gigabyte EX58-UD5, this runs really sweet sind I've bought in 2009, originall with a i7-920 D0 OCed. Later I had a i7-950 D0 OCed and now at weekend or next week finally the best CPU on an X58 so far, a hexacore Xeon.
I've often read that a Xeon is bad to overclock, what do you say?
As i metioned before, all other hardware is fully detailed actually listed at my sysProfile-homepage in signature.
Sorry as an german guy my english isn't that good, hope you understand me nethertheless.
Best regards,
MaXx
@Kelt: After x-times unsuccessfully searches, I scrolled manually through this 180 pages, but I don't found your screens. I found screens from another guys, and one set of these are bit helpful. Please help me to find your pics, or simply reupload it.
Best regards,
MaXx
