Ok, can confirm upgrading to 1.0.0.4 did not make any difference to my RAM issue. Pretty sure now the issue is the RAM itself, otherwise why would only just 1 stick work and 3 others not?
Now need to do some tests on the new BIOS
To get both sticks running I need to go manual and loosen the tRas from 54 to 60. So far doing a quick test that seems to solve the issue. But only way to know for sure is to run memtest for many hours or over night even. But I do know it makes a difference as without loosening that timing I get errors nearly as soon as I run memtest.
Edit: Can confirm there is zero difference in scores running the cpu on stock vs before and after the bios flash on cinebench. Well there is, 2 points slower on the new bios, but that is within margin of error, so basically as I said, no difference.
Now running the single core benchmark. Results are in, it went up from 484 to 486. Yay! Lol
Ok so no difference in performance for me guys. But hopefully will see many other benefits from the 100 improvements that was mentioned.
