- 6 Jan 2013
Wasn't running at all until I did the BIOS update (Aorus Pro) and now running
See my post earlier in the thread, you can only change the keybinds from within the game not from the main menu
Seems to scale crazy well, i just run benchmark at balanced settings and it was flying 90 fps then maxed everything and still got 30fps.
So should play 4k60 most setting quite high on my very ageing rig.
I thought this would be screenshot central this afternoon.
Anyone figured out what the big performance killer settings are other than obvious ones like reflection MSAA etc ?
Remember folks, make a hard save the moment you settle down in Chapter 2 and keep it in order to return to in future. Do the exact same for Chapter 3 also.
Don't run on a single save, you'll only regret it.
In future you will likely want to start over without going through the dullness that is chapter 1 or enjoy the game at its prime (chapter 3).Why's that? Story choices?
