Seems like 4.7GHz is unachievable with my chip. Max I can get it up to is 4675MHz. At least I know know the limits of my chip.
Also know that a all core 4.5GHz needs minimum 1.3175v as at 1.3v Cinebench throws out a error message. I will stick with 1.325v for that setting if I ever use it. But I feel 4.4GHz all core at 1.275v is what is best as it runs cooler and does not push the cpu to hard.
Will wait and see how things pan out with the 1usmus custom power plan. Once the dust settles might give it a go and see if it helps. But not sure I feel like using a non amd approved power plan as it could have long term consequences maybe. If it is something that is very good, AMD may incorporate it or something similar in either a bios or chipset driver update in the future.
I think I am done benching for now. Will wait until my RAM replacement arrives. Until then I will use a mixture of stock settings and my 4.2 & 4.4GHz profiles.
