Windows 10
Permabanned
2 Sep 2017
Microsoft Has Already Finalized Windows 10 2020 – RTM Expected in December
To break all of this down...
  • v1909 release for the public is expected in the next two weeks
  • version 20H1 is internally finalized and will reach RTM status in December
  • version 20H2 previews should start coming to the Fast ring in the next two weeks
  • version 20H2 will RTM in June, 2020 probably being the first Windows 10X version
https://wccftech.com/microsoft-finalized-windows-10-2020-20h2-development/
10 Jul 2010
Windows 10 20H1 users will no longer be able to delete files in the Downloads folder using Disk Cleanup tool - MSPoweruser
Windows 10’s Disk Cleanup is one of the essential tools that help users delete all the unnecessary folders and files that some time eats up a huge amount of storage space. Alternatively, users can also perform a similar function by using Storage sense that’s built into the Settings app in Windows 10.
While to be able to delete unnecessary files from the system by using Disk cleanup or Storage sense is simple and easy, you need to be very cautious while deleting them, because oftentimes users accidentally tick the Downloads box, which, in turn, deletes all the files inside the Download folder.
To prevent this, Microsoft has pulled the Downloads option from the list of items that you can delete by using the Disk Cleanup tool in Windows 10 20H1 Build 19018 or up. Microsoft said that they’ve decided to remove the Downloads option from the Disk Cleanup tool because users wanted them to.
Not just Disk Cleanup, you’ll notice that the Storage sense also got rid of the Downloads option, meaning that you won’t be able to delete Downloads folder from the Storage Sense either.
However, if you’re running Windows 10 19H1 or older, you still see the Downloads option, so it’s safe to assume that those who don’t want the option in the list need to be on Windows 10 20H1 Update or higher.
Finally, it was a ridiculous idea to begin with anyway. To actually roll it out to users was even more stupid of MS.
Permabanned
2 Sep 2017
Enthusiast launched Windows 10 on a calculator
https://translate.google.ru/translate?sl=auto&tl=en&u=https://3dnews.ru/997316
Permabanned
2 Sep 2017
I'm aching for 1909, don't even know why :o
What's included in it?
"Windows 10 19H2 will include optimizations to how instructions are processed by the CPU in order to increase the performance and reliability of the operating system and its applications.
When a CPU is manufactured, not all of the cores are created equal. Some of the cores may have slightly different voltage and power characteristics that could allow them to get a "boost" in performance. These cores are called "favored cores" as they can offer better performance then the other cores on the die.
With Intel Turbo Boost Max Technology 3.0, an operating system will use information stored in the CPU to identify which cores are the fastest and then push more of the CPU intensive tasks to those cores. According to Intel, this technology "delivers more than 15% better single-threaded performance"."
https://www.bleepingcomputer.com/ne...erformance-via-favored-cpu-core-optimization/
Caporegime
8 Jul 2003
In a house
Yeah just appeared after the restart for me too :p
EDIT: and shes on :)
Had a heart in mouth moment after the restart though, came up with the usual configuring, don't turn off, then instead of it configuring, it just came up restarting again, and restarted, so thought, oh no!, boot loop! :eek:, but after she restarted, she just quckly came up configuring again, and booted! :D
Permabanned
9 Aug 2008
You sure you didn't cry when you rebooted? :p mines doing it now.
oh no!, boot loop!
Do you even know what a boot loop is bro? :D
Permabanned
2 Sep 2017
This is normal - 'your system may restart several times'.... ;)
