That's an interesting distinction… You are, unless you want to suggest otherwise one of the UKs premium suppliers of tech, and one of only 5 UK retailers to be large enough to be listed on AMDs website. The UK is one of the worlds largest IT markets.
You say you have only 18 3950X CPUs to sell, and the vast majority of those you obtained through 3rd party 'brokers' because AMDs supply is almost non-existent. AMD have therefore supplied more stock of the 3950X to UK reviewers, than to your entire e-tail outfit. If you can't get stock, are you really suggesting that this is a retail part?
The national lottery has 30 millionaire scratch cards in existence, and you're literally giving odds that I'm almost twice as likely to get one of those than I am a 3950X from you! Are you sure you want to stand-by your assertion this is a retail part, because you'll have to retract your previous statements if you do!
I've heard some mixed messages in my time, but your post takes the biscuit!
Is a Ford GT vapor ware then?
Surely vapor ware is a product that does not exist and can’t be purchased by public?
3950X exist, so does Ford GT they are real and public can buy them and some will get them.
it’s limiter numbers and sold to select repeat customers as the case with Ford GT.
Anyone can buy a 3950X and will eventually get it, that makes it very real they just might be waiting a while.
Was 3900X vapor ware? At launch it was small numbers and was out of stock everywhere hours after launch and stock took weeks to come again and remained tight but its improved over the months and continues to get better.
3950X will be same but worse but as with 3900X the stock will eventually come.
It’s a real product that people can buy and they shall receive.
