All built and running the latest Windows Workstation (for now, my father in law - who is a fellow OcUKer helped me build it and wanted to see Windows on it). I have to say, I'm still shocked at just how plain raw fast this thing is. Like, I knew spending the extra was painful and should be 'worth it' in theory, but to actually see how FAST this thing really is... I mean wth. Windows copied from USB3 at 150MB/sec plus (nowhere near that off the same drive on 8700K, same RAM), and didn't even go to the 'installing' stage of the checklist. It just 'copied files' and rebooted - it was already done.
Things are just so instant it isn't even funny. I don't miss my 8700K. At. ALL. The socket is a joy to work with (you don't really appreciate it on YT videos), and I love the torx screws + heatsink screws built in idea. So simple to work with. I used a Thermal Grizzly Carbonaut Pad instead of paste (more thermally conductive, reusable, no mess) and screwed on the heatsink in seconds... just before it sliced my FIL's thumb open as he installed the 2nd CPU 8 pin. Oops.
 Those things are
sharp.
Idle is around 32 degrees, with late 30s under 'general load' (web, VPN, Cinebench open not running, few background processes etc). Full load is coping OK so far - several back to back Cinebench runs saw me hit mid 60s and the same for an Indigo bench run. I suspect it'd keep climbing if it was, say, transcoding. It'll do until I can justify a custom loop (next on the list!) though, and does cool down very quickly indeed (65 to 35 in about two seconds), so it does have good capcity and great contact.
Now I'm off to play.
 Thanks for all the advice chaps.
ETA: It is so quiet! I'm used to 240mm fans on the front intake pulling in through the front panel mesh for the AIO, 360mm in the roof and 140mm on the rear. Now I have 140mm on the rear and 140mm on the air cooler (not counting the VRM/chipset/GPU fans). Bliss. I do need to add 280mm Noctua fans to the front tomorrow though, just for proper airflow.
Edit 2: Just for those reading and considering TR, here's a quick Indigo Bench comparison between my old 8700K overclocked and the same 32GB of 8Pack RAM at 3600MHz. Ignore the 3.7GHz that's just the baseclock and Indigo didn't see the overclock just the chip's reported base clock.
		Code:
		Indigo Benchmark v4.0.64, Windows 64-bit build.
Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (GenuineIntel) - Bedroom: 1.024 M samples/s (1280x720, 60.063 s, 66.731 samples/pixel)
Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (GenuineIntel) - Supercar: 2.506 M samples/s (1280x720, 60.063 s, 163.347 samples/pixel)
		Code:
AMD Ryzen Threadripper 3960X 24-Core Processor (AuthenticAMD) - Bedroom: 3.865 M samples/s (1280x720, 60.125 s, 252.143 samples/pixel)
AMD Ryzen Threadripper 3960X 24-Core Processor (AuthenticAMD) - Supercar: 8.671 M samples/s (1280x720, 60.063 s, 565.134 samples/pixel)
