- 2 Aug 2016
- Everywhere
Yeah, they are up now on Ncase website, went for the Silver.
Could you give me a link, for some reason I'm struggling to find it.
www.ncases.com
Put in an order for the black one for my next build. Check out Optimum Tech on youtube for build tips if needed.
Maybe we should start another thread for the Ncase m1 now that they seem to be in stock, i'm sure there will be a few people here picking one up here.
@wookiee87 if you're still about, how is the A4 treating you? I'm very tempted to pre-order!
Awesome, really appreciate the feedback! Yeah, I'd go for the Asetek unit alright - it should cope nicely with a 3700X. How has the Strix been for you?i'm still here and rocking out with my dan a4, temps are really good now after tuning the gpu, set a lower power target 70% and the card hits just under 60 degrees whilst maintaing 120fps at 1440p, regarding my 3900x its at stock with pbo and hits around 4.4ghz at full chat and temp wise just over 72 is the most i've seen, mosttly in the mid 60's during gaming. got the astek 645l 92mm aio installed to
if your looking for the ultimate in small form factor then the dan a4 is your choice, tuning is needed but hell its worth it in the end.
also added a corsair mp600 pcie gen 4 ssd and its an absolute beast
Really tempted to get this case, was looking at this or an a Ncase M1 ,
but will a EVGA GeForce RTX 2070 SUPER XC HYBRID GAMING, 08G-P4-3178-KP, 8GB GDDR6, WATERCOOLED Fit with a Ryzen 3600 system air-cooled and a Corsair sfx 750 ? It’s a lot of money for a case, but do love seeing these SFF builds,
I currently have the above GPU sat in my Alienware amplifier aka egpu, but been thinking of a SFF build for a while
The A4 only supports a 92mm fan/cooler, so it won't accommodate the EVGA Hybrid cooler, I'm afraid.
thanksA4 is really nice, but pretty crappy with using high end parts.
I have a Ghost, Best case I have ever had - can't recommend it highly enough. (I also have a Dan). Turn the internals upside down so the fan is at the top and you don't even need to use a top hat to get reasonable cooling.
9700k @4.9ghz using a Big Shuriken 2 cooler and a EVGA XC 2080. Temps are good unless I run something like Realbench for 30 mins on the OC CPU.What CPU and GPU are you running and have you tested temps?
Waited to get my hands on a ghost for months and they're finally in stock in Germany so if temps are fine then I'll be grabbing one.
Out of interest, where is it available in Germany?What CPU and GPU are you running and have you tested temps?
