One reason I moved away from IPS. Most of them are like this with IPS glow/bleed which ruin the experience. If you use in a bright room with moderate brightness then it’s usually not noticeable. In a dark room then just the glow alone can be very noticeable and distracting especially if you play dark games.
I went to a VA and haven’t looked back. You do get some slight ghosting in some games but nothing particularly noticeable. And blacks are nice and uniform.
Everyone raves about IPS but for gaming I think it is the worst. Even TN doesn’t have this issue and when setup correctly can look good. In games you wouldn’t even notice the difference between the two technologies aside from IPS glow
Every panel technology has its own pros and cons. Even OLED aside from burn isn’t perfect.
Just today’s QA standards unfortunately.
