Where are you mate, I have a GT Omega rig that I cannot get rid off, no seat on it, but you could pick one up from a scrappy for a few £s..Great thread. Been looking to replace my old G25/Generic frame which I had to get rid of after moving house 3 years ago. Salivating at some of the setups in here, unfortunately most way beyond my budget but I'll get something sorted![]()
I'm near Newcastle.. cheers for the offer but the reason I got rid of the original stuff still stands (lack of space). However I'm thinking VR allows me to squeeze a bit more out of my tiny room, as I don't need the space for monitors. Looking at some sort of decent wheel stand and an Oculus Quest. I know there's better out there but if I get the quest it can come downstairs, the family can have a play etc. Makes it easier to justify to the better half![]()
Where did you get them air flow straighteners for the fans?Where are you mate, I have a GT Omega rig that I cannot get rid off, no seat on it, but you could pick one up from a scrappy for a few £s..
Also, added wind to my rig now.
Two Noctua industrial fans at 3000rpm each pushing 157cfm, its like the Antartic at full pelt
Had problems with the black PLA so switched to other stuff, might paint them later, but as right now i'll leave it be.
https://www.thingiverse.com/thing:3843782Where did you get them air flow straighteners for the fans?
I'm way out of league in here, but hope someone can help.
Looking for my first wheel setup, thinking about the G29 or T300rs. What can you recommend?
The T300 looks a better wheel, but worse pedals than the G29.
Having owned both, the T300 wheelbase and wheel upgrade options are on another tier. The G29/920 feels like a toy with its geared FFB mechanism. The FFB feel and consistency are just far superior. but like you have said the pedals (T3PA) are nothing to write home about, functional at best... there are mods available but nothing that will make them great. I bought the T300 off a mate knowing I was going to upgrade the pedals and eventually replaced them with HE sprints, just in time it seemed as the day before I received the Sprints the TM pedals piled in. I'm not suggesting that you go out and buy sprints, they are expensive, and there are some more sensible and affordable load cell options like rjk mentions the CSL's or TM's T-LCM however my opinion is still out on TM's offering until I get hands on.I'm way out of league in here, but hope someone can help.
OOOoooffff... She sure looks the part!Lst thing I am buying, honestly!!!
Anybody here running simucube? I'm a little confused with the wheel options available for it and want to weigh up the options of going fanatec clubsport / fanatec DD /another DD option.
I'll throw a rig update in here soon as I've added over the past few months to the point where I feel like my setup is really only lacking a shifter and a higher performance wheelbase
