- 1 Dec 2015
@Plec , yeah i work- ish
**** - I'm going to have to try a different case. 4 screws (top 3 and second one down nearest edge of backplate loosely fitted to limit sliding) and, still operational with driver installs and 6 restarts. I realise, very limited testing but it would have normally corrupted by now.
It's not really proved anything more that i'm already assuming but it's another piece of evidence that's forced my hand into testing in another case after i've finished a few calls :/ (Damn you @Danny75- i knew i had to do it, but i needed a shove, your test gave me no way out, kudos, and #$*&ing bloodies!)
Cheers @Danny75Best of luck new mobo sorts it, does seem like it's been narrowed down to that now.
Cheers @Danny75
Ordered a replacement from OcUK - should arrive tomorrow.
Awaiting reply from Customer Services forum but they're usually pretty good (suspect they're busy with lots of panic buying/prices) and i've been as detailed as i can, outlining fault. Plus, the RMA (refund of the new board - as it's gone up) should be a formality, in theory. Especially, if i have an up and running system tomorrow...
But, appreciate that they're probably busy so refund delay is small price to pay for up and running workstation (i hope!).
i bought a new one - and went for refund.what you go for buddy ???
if under 14 days should be very quick, unless MSI is very slow
*Wouldn't OcUK test it?
Forgot about the heatsink (would have bought the other bequiet) - but the Dark Rock 4 should be fine on a fully functioning board. I've fitted bigger coolers on flimsier boards and never had a problem like this. Admittedly, no m.2 slot...new B450 toma ? Pro-A is same board but smaller heatsink
OcUK are dealing with the RMA as I type (very quickly and courteously i might add) - so much easier using their CS forums.
Ordered the same as i need to get a workstation up and operational as soon as possible now. I was familiar before with the board - now i know it too well, but will help with speedy setup.order the xtreme for yourself then ?
) and @StigBourne were excellent in the past too - presuming they still are but not crossed paths in a while (although i think yewen moved on - i can't keep track, i've been on these forums too long.)
Thanks, @doyll, appreciated your input.Fingers crossed all works as it should with new motherboard.
My hat is off to you. You've done a lot of trial and error testing in short amount of time.
And without spring loaded screws there's no sure limit for force caused by mounting system of cooler itself.
It does - but from my experience (I'm not as informed as you with coolers) - i've found that the bar method has to apply, initially, more force to level out the bar - this has never concerned me in the past.Spring pressure on IHS from base of cooler is determined by design, same as mounts without springs. All of the top tier cooler companies design their mounts to applie the right pressure. It doesn't matter if they have springs or not, mounting pressure is most important part of mount design. Hope that makes sense.
You're killing me @Danny75I've managed to overtighten a Noctua NH-D15S in the past so the system wouldn't start until I loosened the screws a quarter-turn or so. Don't ask me how I managed to fumble that... I guess I was expecting the spring screws to just stop turning beyond a certain point.
