They need reporting to the police ASAP before they kill someone.
They will most likely just ask for a longer version if what they see is bad enough to trigger a response.Reported it so removed footage above. Though realised after I'd submitted it the time was shorter than they requested before/after :s for some reason I didn't read that bit until after it had started uploading.
Get rid of the P plate for a start anything like that is an invitation for people to do silly stuff as you've seen. They certainly won't buy you any room or extra patience from 99% of drivers.So I’m going to need a dashcam, front and back if it’s not too expensive. I wasn’t going to bother but I only passed my test in February and seen some scary stuff around me.
Friday night I was first in at a red light and the guy behind me (probably after seeing my Plonker plate) pulled around me to run the red light.
Saturday someone hit my parked car, damage is really minor and she knocked on the house to own up but I know the cameras on the trucks at work would have picked that up. If anyone should be dinging my first car it should be me!
My dad recommends his but it’s a cheap Lidl one and it’s awful.
What kind of budget do I need to be setting aside? I can see the packages at Halfords obviously, but worryingly I trust you guys!
Any recommendations for a hardwire for a Nextbase 412GW? Thanks!
You mean someone to do it for you or how to do it? Nextbase themselves sell a suitable hardwire kit, you just then either need to wire it up yourself or get someone to do it. You might be hard pushed to find a place to do it given the current climate but even Halfords can do it if you trust them with your car. If you are comfortable messing about yourself check YouTube and someone may have done a neat job of it already for your car's make/model.
Apologies, I meant hardwire kits! I’m happy installing![]()
