No problem. I did a lot of research and honestly had the differences been bigger I would have gone C9 myself.I'd not seen that the B9 could do VRR and supported 2.1 _ I knew it had the same chip from the year before I was not aware they had added 2.1 support to that - so sorry about that.
Please explain further what you mean. Because as far as I am concerned what you said is completely wrong. They both have same display and HDMI 2.1 and G-Sync, what is the C9 chip doing that makes it “infinitely better” exactly? If that was the case I would have gone C9.
All the C9 has over the B9 is a better cpu and 1GB extra RAM which helps a little when upscaling. It has slightly higher peak brightness for HDR and is meant to be slightly better calibrated out of the box.
https://www.nvidia.com/en-gb/geforce/news/g-sync-compatible-2019-lg-tv-available-now/I didn't think that the B9 had Gsync. Got a link?
All the 2020 range OLEDs from LG support it![]()
Yep and all 2019. I got an update on mine a few months back that enabled it. Yet to try it out though. Likely won’t until I get an RTX 3070 in a few months when they come outhttps://www.nvidia.com/en-gb/geforce/news/g-sync-compatible-2019-lg-tv-available-now/
The 2019 models do too![]()
If it’s the correct model
LG OLED48CX6LB 48"
without linking to a competitor it’s on hotukdeals now for £1499.00 on the high street
Nice. Look forward to see how people find it. Hopefully it all works out and no screen burn issues that way I can pick one up on the next Black Friday.Just pre-ordered. Now to wait and see if the shortage rumours are true and how bad.
I agree. 32" would be perfect, hell I would even be happy with 40".I'd lover a smaller OLED TV/Monitor, but 48" is still way to big32" Would be the max I'd want to go for 16:9 or 34" in an Ultrawide OLED
and it means you can switch between 4k and 1440p @ 120hz depending on how demanding the title is![]()
Just noticed there are two versions on the big retailer.
OLED48CX6LB 48" - £1499
OLED48CX5LC - £1299
Anyone have a clue on the difference?
OLED48CX5LC - £1299
