Man of Honour
- 8 Nov 2007
- Outer Space
Yes they have xmp c14 3600mhz.Do these have an XMP profile?
Dear me... Do you want a crazy good price on very low latency and high quality memory kit?? Gibbo has done a great job with the pricing of this..You might want to check with Trading Standards with regards to reference pricing.
only if they are RGB hahahaDear me... Do you want a crazy good price on very low latency and high quality memory?? Gibbo has done a great job with the pricing of this..
Not that I mind having C14 3600 in an easy to configure XMP but I take it these are the same RAM modules already sold but just with a bump from 1.35v to 1.4v in the XMP to make C14 possible?
I would guess these are a slightly better bin than the old ones as these will have Been tested to work at those timings where as the older ones would have been more of a lottery.Not that I mind having C14 3600 in an easy to configure XMP but I take it these are the same RAM modules already sold but just with a bump from 1.35v to 1.4v in the XMP to make C14 possible?
Nope, these are binned separately, it is also why it has taken nearly a year as to achieve this spec comfortably in a wider range of mainboards means separate binning process, so they are better yield modules and also do require the bump in voltage to achieve the timings.
Considering the binning, what's their OC potential like in comparison to the previous ones? Obviously allowing for the silicone lottery.
The 3600/14 ripped kit would be the best kit for ryzen 3000. You might be able to manually overclock the other kits to those timings but it's not a given, these are ready to go out the box.So forgive the silly question but which kit is going to be faster for AMD? I'm assuming the 3600MHz as Ryzen seems to love fast RAM but then there seems to be some benefit to tight timings as well?
Assuming your mobo and CPU can handle it.....The 3600/14 ripped kit would be the best kit for ryzen 3000. You might be able to manually overclock the other kits to those timings but it's not a given, these are ready to go out the box.
I can run either 3600/14 or 3800/16 on my cheap b450 tomahawk so I'm guessing it will work for the majority of boards.Assuming your mobo and CPU can handle it.....
True. In general the current kits mostly do this. I wonder if it's just binning and a new XMP profile for those that bin higher.I can run either 3600/14 or 3800/16 on my cheap b450 tomahawk so I'm guessing it will work for the majority of boards.
Would my 2700X harm my chances?
