Is there any magic settings I need to be using in either the VD app on my desktop, or on the Quest side of things.
It's worth downloading a wifi app for your phone to find a 5ghz channel that's not congested and set your router to that. Other than that the connection reliability really does seem to be up to how good your router is.
I can get a good wifi signal down in my living room, but get lagging and disconnects. The connection is rock solid in the room with the router, but there I don't have the room to make proper use out of the freedom that comes from using wireless.
Sod all wrong with it. Do you work for Kiwi Design?
