I saw the new star wars yesterday and was underwhelmed with both the sound and picture. We are getting to the age where a better than cinema experience can be had for a ‘reasonable’ amount.... just need 70”s to come down in price....
That's what I do. I can sit about 2m away.Just sit closer....![]()
The problem is the 2k intermediate most films have to comply too, theres nothing really pushing visuals outside of HDR .I saw the new star wars yesterday and was underwhelmed with both the sound and picture. We are getting to the age where a better than cinema experience can be had for a ‘reasonable’ amount.... just need 70”s to come down in price....
It's not a surprise to me anyway but you'll see from these videos that the CX has an advantage compared to the Samsung even in a bright room while gaming. The Samsung just can't achieve it's peak brightness in game mode and in many scenes the LG OLED looks even brighter than the QLED.
Turns out the 10 series OLED's don't support full 48Gbps bandwidth HDMI 2.1
https://www.forbes.com/sites/johnar...d-tvs-dont-support-full-hdmi-21/#49d21a436276
But according to Vincent Teoh and Adam Fairclough (Evil Boris), it won't really be an issue as the panel is 120hz 10bit native, the 40Gbps limit means you can 'only' max out at 4k/120hz/444 with HDR and can't push up to 12bit - which the panel can't display anyway.
	What it like using the default apps for things like Netflix and Amazon my two sources.
I'd also be looking to use Plex though I have a feeling in still better off using an shield Pro as I want it to run the media server.
Also what's the difference between the 5LB, 5LC, 6LB and 6LA models?
The 48 seems to come in either 6LB or 5LC.
Netflix is ace, though I dislike their menu UI as it starts content playing with audio if you hover.
Sounds like I'm better off just using a shield Pro for everything then.I use native Netflix and Amazon apps for maybe 50% of TV viewing. Netflix is ace, though I dislike their menu UI as it starts content playing with audio if you hover. Amazon app is... Pretty pants and bad UX but I test smart TV apps for a living. It works fine, and video itself is grand.
I mean my beef is with the app design which is probably the the same on any box. But there's a lot to be said for doing everything through one remote. For me that's the LG oneSounds like I'm better off just using a shield Pro for everything then.
EPIC, thanks!You can turn that off in your account settings (via a web browser, not from the app).![]()
