Scratch build valve power amps
I've had some problems with rather excessive DC voltages which were causing excessive plate dissipation. (evident in the photos above as the orange glow to the grey metal of the plates in the EL34's) Checking the voltages, I was seeing around 20V more than I should have
I spent some time going over the datasheet for GZ34/5AR4 and realised that there is a minimum resistance per plate that I'd not realised would need to be checked.
The valve wizard site also happened to have a handy formula for calculating it. (Rlim = Rsec + Rpri × (Vsec/Vpri)^2 + any extra resistance)
V Pri = 250
V Sec = 398
R Pri = 5.7
R Sec = 88.5
Result = 102.9464448
This put me a tad short of the 125 ohm minimum at 2x400V. (although they only list it for 60uF filter) I spent this morning having a good dig through my component stash and found a pair of 5W 60R vintage RS branded resistors which I've fitted in the 410-0-410 feeds from the HT fuses to the rectifier socket.
These are the measurements I got with these 60R limiting resistors in place. The numbers look significantly closer to the book figures now. I'm doing some testing this evening and will check with the camera to see if there is any sign of glow in the plates.
Mains voltage - 237.3Vac
HT voltage - 391Vac
C15 - 458Vdc
C12 - 441Vdc
C5 - 410Vdc
C4 - 165.5Vdc
V4 Anode - 431Vdc
V4 G1 - 0.7Vdc
V4 G2 - 433Vdc
V4 G3/Cathode - 30.9Vdc
Heater - 6.0Vac
V3 Anode - 431Vdc
V3 G1 - 0.6Vdc
V3 G2 - 432.5Vdc
V3 G3/Cathode - 30.4Vdc
Heater - 6.0Vac
V2 Anode 1 - 303.6Vdc
V2 Anode 2 - 303.7Vdc
V2 G1 - 88.4Vdc
V2 G2 - 80.4Vdc
V2 Cathode 1&2 - 92.8Vdc
V1 Anode - 88.8Vdc
V1 G1 - 0 (no signal)
V1 G2 - 110Vdc
V1 G3/Cathode - 2.1Vdc
Heater - 6.2Vac
The plates now look much healthier, though the camera can still see some infrared. I cannot see it with my own eyes in a pitch black room, so I think it's ok. Still sounds great and no audible noise that I can hear through the speaker although the mains transformer does hum slightly but it's not mechanically isolated from the whole assembly.
Bought some spare valves to save me wearing out the more expensive and vintage ones. The JJ's are cheaper so I can afford to give them a harder time whilst I'm testing trying to debug issues.
Tung-Sol EF806 SG replaces my vintage General Electric 6267
Tung-Sol 12AX7 replaces my vintage Gneral Electric military 5751
JJ KT77 replaces the Tung Sol EL34B
JJ GZ34S spare in case one of the Sovtek 5AR4 happens to fail
Dare I say it, they may actually run better than the Tung Sol EL34B's I was using as they seem to operate more comfortably with the biasing set by the original design. (No signs of any glowing on the anodes) They don't have the holes in the plates though, so they emit a lot less blue/violet onto the glass envelope.
The debugging has not been going as well as I'd hoped. I'm pretty baffled by an errant oscillation issue that I know is caused by the negative feedback but I cannot seem to iron it out and I'm beginning to suspect that the current layout is the root cause. Things get a bit nasty when you overdrive it.
Things were also getting quite chaotic with sub sonic inputs, which although unlikely are still a risk when playing records when the preamp doesn't filter it out. This is what things got like at roughly 12W and 10Hz. It was massively worse at lower frequencies as it would do it at 6Hz with only 3.7W out.
I've dealt with that issue by sticking a 0.01uF capacitor in series with the input which in tandem with the parallel 1meg ohm resistor filters out the LF below 20Hz. The drawback is that there is a definite drop in the frequency response at 20Hz so I may need to drop this value to around 6.8nF.
Graphs plotted for frequency response vs RMS output voltage for a given RMS input voltage. https://docs.google.com/spreadsheets/d/1_TqbGV73X5MK0Hq3FalolIpyPtJxTQTNwEOtzpezPZI/edit?usp=sharing
Mk 2 Version...When all else fails, do it by the book. This is pretty much as close to the book layout as I can get. The capacitors may create some fun with the wiring but I don't think it'll be far off standard. The two capacitors that live between the 9 pin valves will be the hardest as it's supposed to be a multi-element electrolytic which I don't have. I chose to go with a pair of 10uF MKP caps originally so I foresee either some major fiddling or me buying a multi-element cap.
The connections to the output transformer from the output valves in the standard design are significantly shorter and the B+ runs in the opposite direction too. I'm also planning on connecting up the mains switch this time. I may even rectify the one 6.3V heater line in order to get the power LED to work too.
Progress on the MK2 has been pretty good so far. I've concentrated on the woodwork side of things using yet more scrap bits. The chassis is basically complete. I've decided to put significantly more tag strips in this time to help distribute the wiring about more tidily and following the mullard layout pretty much to the letter. All the large can capacitors are mounting onto the side panels with the terminals being kept as close as possible to their normal locations. I also shrunk the tag board down significantly. There is so much more space inside now, it's much easier to work on.
I don't know how you are doing this but it's amazing!
I like this! Following with interest
Thank you both, it's proving to be quite the challenge to do a decent job on the build front. The results will hopefully befit not only the amount of work involved but also the significant cost.
Progress so far has been fairly good. Heater wiring is proving more challenging with the standard layout. I'll also have the challenge of soldering the live/neutral wires onto the on/off switch, making sure they are sleeved and remain twisted.
I finished off the wiring at the very end of April. Wired the mains push button switch in this time which is very nice.
Testing the amp proved that the problems I had with the first build were not related to the layout. Still cooking valves for no good reason.
and still getting unsettled towards the 20W it should be able to output cleanly.
This led to me looking at the Claus Byrith modifications which converts the front end from a pentode input to triode strapped input. The rest of the modifications are far more difficult to achieve as it would require a negative supply. This has the alterations needed to the turret board. Thankfully it's simply removing a few components and swapping others. No need for removing or changing the turrets themselves.
Schematic for this design.
This tested significantly better albeit with some issues still lingering so I ended up disconnecting the feedback completely and running some open loop tests between the anodes of the input valve and the phase splitter as there is definitely something iffy going on. 10KHz square wave input, close to square out of the EF86, utter crap out of the 12AX7.
Took the EL34's out of circuit and tested again. Very suspicious. It definitely looks like the above issue related to stray capacitance.
Someone suggested that the octal sockets having the stray capacitance was a real possibility since the above was measured at the point the signal would enter the grid of the EL34. I replaced the old finder sockets with some new belton ones. Things improved a bit.
I'm now working on constructing the metal chassis from scratch with some spare scrap aluminium I have floating around. (19" 6U rack blanking plates) I was thinking of using aluminium U channel to make up the sides, but having seen @Sam__ 's scratch build project, that bosch rexroth aluminium extrusion system looks very interesting, if perhaps a bit expensive.
Finally got the sheet metal punches so I've made a start on my aluminium panel. This is re-purposing a 6U rack blanking cover to make the top panel. I've not put the bolt holes for the noval sockets in yet as I had no spare sockets that weren't already mounted to the wooden prototypes. I'll probably leave the cooling holes out for them as the miniature valves seem to run fairly cool. Still got all the holes for the tag strips, earth bus bar and turret board to drill.
Finished drilling all of the holes. I've now countersunk those that need to be and fitted the standoffs. Just got to deconstruct the wooden version and transfer the parts across.
Impressive stuff, wouldn't have a clue where to start with this. How would the quality you can get with self building compare with bought? ie if you had to buy an equivalent how much would it cost? I know that's not the point, the fun is in the building, just curious.
It can be done quite cheaply if a known build is followed precisely using the same parts as very little in the way of tools is needed. If you have to buy a boatload of tools, it doesn't work out cheaper, particularly if you need any test gear. Oscilloscopes, function generators and audio analysers are seriously expensive.
Solid state (transistors/mosfets) hi-fi can be done far cheaper as there is no need for the extra expensive output transformers and a transistor at worst is about £3. Valves cost anywhere from about £8 up to frankly insane levels. (particularly as they have a finite operational lifespan) The transformers that are needed are equally as bonkers, usually anywhere from £80 out to the thousands.
It's 100% the transformers that kill the budget with valve amps. Parts add up, especially quality ones, but transformers don't really have a cheap option and they're usually the priciest bit.
You can spend serious money on solid state stuff heh - I've been building headphone amplifiers using DC-DC POL devices that have a mini-transformer and ground loop isolation to generate a negative rail and then some serious filtering after that and they are £10+ a pop.
How many of these components would you need to build something?
That is a bit of an open ended question - you'd have to be more specific.
The headphone amplifiers I usually build have 2x £10+ POL, 2-4 opamps (can be anything from £0.5 each to £50+ each) the rest is a bunch of a dozen or so capacitors and resistors which are generally fairly cheap and a couple of voltage regulators which are generally around £1-3 each (plus the sockets and volume control, etc. which again you can spend anything from £2 to serious money on).
That didn't sound too bad when you look at the money they charge for decent hi-fi gear. I'm amazed how much they can charge, especially for cables!
Some changes are afoot. I've decided since the standard design has some known drawbacks with the choice of valve for the phase splitter and I need to make a few tweaks anyway, I may as well integrate some bigger changes. With the help of some kind fellows on DIYaudio I've got the following schematic allowing the change from 12AX7/ECC83 to 6SN7/6CG7 for the phase splitter. A CCS (constant current source) has been integrated into the "tail" in order to force balance the pair and improve linearity. Zeners have been introduced into the cathode bias on the outputs in order to reduce the standing bias but also reduce the losses across the larger resistors that would normally be used to reduce the bias. Whether this bit works or not, at least sonically, is something I'm not 100% sure on.
New turret board layout. The CCS part is being made on small veroboards that will tie into the turret board.
The living room table has been turned into organised chaos.
Progress so far. One thing I did discover during my teardown was, what I'd thought was a 220nF capacitor off the link between the phase splitter grids turned out to be a 22nF cap. (which has been that way right from the start as somehow I ordered the wrong value) 3 extra turrets have been added for the new sections.
