All core i believe is 4.6, 4.8 is single, but that means they should manually overclock to 4.6ghz, maybe a little more.
Holy crap lol, a 3900xt would be really tempting but nah ima still wait for zen3
We should see 5.0 on Zen 3 hopefullyUnless they troll and go 4.9 LOL
I hope so. With improved IPC it will be awesome. Can see myself picking it up a 4900X in 18-24 months time as they get major price reductionIf true, 5Ghz Zen 3 inbound......
Wonder if they'll bump the 4600 to be an 8 core part.
...which to most isn't worth it unless you have significant productivity demands.Would love this. Going from 4/4 to 8/16 would be worth it, just can't justify a 6/12 upgrade. Ideally a 12/24 but that's probably overkill and will cost £450+
Indeed. Reworking the CCX design into a single 8 core unit will net bigger gains than increasing core counts. 5nm shrink and a rumoured total rework of the chiplet design opens up possibilities for core count increases in Zen 4, but even then I can see that only happening at the lower and mid SKUs: 8 cores across the board with 12 and 16 if you want them. I could see a 5950X with 20 cores just to rub Intel's face in it a little more though, but unless Rocket Lake's successor moves past 10 cores (hell, rumours suggest Rocket Lake isn't even getting 10 cores) there's no commercial reason for AMD to move past 16.I suspect they'll maintain the core counts per model, at least for Zen 3.
4.6 all core boost would be a significant boost, I'd be surprised if this was the case. Current 3900X only do about 4-4.1 stock.
Most 3900X's that I have seen, mine included can do 4.3 fairly easily. I agree though 4.6 would be a big multithreading jump.
mine is pish. 4.3 at the highest safe voltage. will do more with unsafe 24/7 voltage. I just leave it on PBO.
I ended up doing that too. I am mostly a gamer and on PBO 4 cores will hit 4.6-4.65Ghz so I just left it on that. It's better for me than 4.3 all core.
4.6 all core overclock is not unusual for people who bought Zen 2 cpus recently (from quick look at overclock.net forums)
tech process matures
And it will still be subject to power limits, so will not be held for long.
I'm on an x470 board with an older bios. mine doesn't get that high. will be getting the x570 tomahawk when its released.
how many 3900X bought after March 2020 and tested for overclock are there?4.6 all core on the 3900X would be very unusual.
