GPU drivers gained the last 300Well with uplifts like that how can you complain! What did you change? I still think you could get closer to 4,000 but there could be many factors causing it.
I’d be inclined to test them as-is with a diag card (POST card) as this will show you if the rails are good, and assuming you can watch the POST procedure properly on the card in each of the slots then you are golden. I’d only add contact cleaner or DeOxit if you have issues. Unless of course you can see corrosion.Got 3 PCI and 3 ISA slots which have never been used, is it a good idea to spray contact cleaner in them?
That’s more likely to be a resource conflict then if the slot works fine for some cards. I’d imagine being a pre-SS7 board then it’s resource management is going to be sketchy at best even if it does have a semblance of plug ‘n’ play in the BIOS.Makes sense, thanks.
First two PCI slots will not display a post screen with a video card in, even with onboard disabled, card works fine in 3rd or 4th slot, however first works for a SB Live card.
Shame there’s nothing unique or interesting about any other part of that PC, could prove hard to shift once the AWE64 is out of it!If anyone wants a Cheap(ish) AWE64 Gold with 12mb ram card then buy this: https://www.ebay.co.uk/itm/Pentium-PC-DOS-Gaming/264748578504?hash=item3da43eb6c8:g:~WoAAOSwOJVe00~E
And resell the remaining PC, other golds are currently listed for £200 - £250.
Bargain!I could buy it and sell you the case with free contents, excluding soundcard for the bargain price of £150.
220, 5, 1?Having a nightmare getting the SB Live 5.1 to work in DOS, SB16 emulation is configured correctly, IRQ is not shared with anything else, yet load Duke3d and the program refuses to find the soundcard.
Using the vxd drivers at the moment, just about to switch to the retail cd drivers see if that is better.
Would need to be broken for parts probably then scrap the case, not sure how it would work out money wise, Buy now prices for AWE Golds seem very high vs the £100 some have sold for on auction
