- 25 Aug 2008
- York, UK
How you getting on with this mobo?
Bios did my head in at first, but used to it now lol
Yes, I have latest bios.Are you using the latest bios, I think that was an issue with the early BIOS?
Thanks, you’d certainly notice it it’s extremely loud for such a small fan.I don't have that issue with my board, not that I have noticed anyway
Small fans are loud, the 30mm fans on EVGA X299 was bad enough.Thanks, you’d certainly notice it it’s extremely loud for such a small fan.
My friend hasn’t adjusted his and neither have I. As mentioned it only happens in the 5 or so seconds when I turn the machine on or reboot. Apart from that the fan I don’t think even comes on or it’s certainly silent if it is.Has he adjusted the fan profile in bios?
I have mine set to silent, with the main CPU on full (using an AIO cooler)
Mine does this.Question for those with revision 1.0 (original release) of this board. When you turn your machine on or reboot does you board fan go into audible overdrive for 5 or so seconds? I ask as a friend picked up revision 1.X (new revision) of the board the other week as his doesn’t do this. Yet my old revision board does.
