Caporegime
- 8 Jan 2004
- Rutland
So my BT contract was coming to a end so yet again I made the stupid choice to switch providers and went back to Plusnet after being away for 4-5 years. They took over the service on Monday and I am getting 30mb (was a solid 36mb with BT) at the moment but hopefully that will rise as the line training goes on. The problem I have is that the wifi is abysmal. Nothing will stay connected to either the 2.4ghz or 5ghz signals and once disconnected won't reconnect and even if they do connect it says connected to router but no internet available which is what it says at the moment although the hub has a connection to the internet as I am connected on my pc using a ethernet cable. Reading through the last page of this thread it would appear that this is a common problem with Plusnets supplied Router and the usual fix is to use a different router. Basically I have no wifi at all.
I still have my BT HH6 which I suppose they will be wanting back if I remember right from the last time I was with them and left so can anybody recommend a reasonably priced replacement for Plusnets hub please? If it's to be a BT HH how on earth do I configure it to work with Plusnet?
BT won't want your Hub 6 back. Just use that instead of the Plusnet router. All you have to do is change a couple of settings:
https://community.plus.net/t5/Library/Using-a-BT-Homehub-3-or-2-on-Plusnet-ADSL-or-FTTC/ba-p/1322578
I do this everytime I bounce between plusnet and BT. Also means all your devices don't need to be reconnected.
