My 55 is due Sunday and I'm very stoked. Had a 42" lg lcd for 10 years and been itching for a upgrade but couldn't justify it since they're was nothing wrong with it.CX 65" is scheduled for delivery Thursday next week, cannot wait.
The VESA holes are lower as the main chassis of the TV is only along the bottom. So you'll need to put the bracket lower than expected. Honestly though, I'd wait til you have it all with you. I have a 55 and might be able to measure but it's not that easy to communicate all the variables!My wall mount arrived today. Is there somewhere I can find out where the vesa mount is positioned on the TV? (55") Is it central or higher /lower to the centre?
I want to get it on the wall ready..
So excited.
Not felt like this since last time santa visited
Thanks man. I understand your point in waiting but I figured if I got a piece of cardboard I could 'dummy' it up and get the bracket on without any weight, cos the bracket weights 8kg in itself. Was hoping for a diagram somewhere online...The VESA holes are lower as the main chassis of the TV is only along the bottom. So you'll need to put the bracket lower than expected. Honestly though, I'd wait til you have it all with you. I have a 55 and might be able to measure but it's not that easy to communicate all the variables!
TV is 70cm tall and 122.5cm wide. Top screws are 35cm from the top edge. Bottom screws are 14cm from the bottom. Allowing for 1cm error due to screw heads etc that sounds like they're 20cm apart so the numbers add up.Thanks man. I understand your point in waiting but I figured if I got a piece of cardboard I could 'dummy' it up and get the bracket on without any weight, cos the bracket weights 8kg in itself. Was hoping for a diagram somewhere online...
Anyone upgraded from a Samsung KS9000 to one of these? Opinions on whether it's worth it? Due to recent wins in the stock market I'm sorely tempted by the 77' version but would happily settle for a 65' if the difference is big enough. Just don't know if the upgrade is worth it over what I have at the moment. I've had a proper look at the 77' in store and while it's undeniably gorgeous, I just don't know how gorgeous over the KS9000. The only thing is that I have the KS9000 in 65' so replacing it like for like with a 65', don't know if that's going to be much of an eye-popping upgrade. I'm almost forced to go for the 77'.
So no BX model until September time and do you know if there will be a 48" BX Gibbo from your contacts ?
Not hearing of a 48" BX sorry.
No problem Gibbo was just curious if they would release a cheaper model of the the 48"CX. Enjoy your tv when you get it
that raised the question of whether a panasonic/sony oled a year back would have, already, delivered the same motion quality.Overall definitely impressed, feel it is quite a leap from my B7 ....
