- 11 Mar 2013
White is good, do you still need to plug the cable in? I'm assuming it doesnt light up at all without the USB cable
TBH I'm tempted by the NH-U9S still I havent seen a negative review for it yet, just pricey with adding two Chromax fans
I would get that cooler instead. Its just a tight fit and will only work with mesh panel,but you never know it could just fit? The U9S is expensive but think its worth it if you have the funds available?
The Cryorig cooler led under fins need usb header. It’s fine for me because I won’t be using that for anything other than this cooler.
Just need decent slim fans for bottom and those I mentioned earlier are perfect. Noctua fans are the best for silence.
