How come so many of you are considering air options? I thought most would go for AIO given the room this case has.
I'm currently looking for a new GPU and some of the ones I like are around 315mm in length, I mocked-up the below layout to show that it may be possible to run a 315mm length card with a riser cable and still custom mount an ATX PSU.
Could be an RGB thing. RGB CPU coolers, RGB RAM, and even RGB GPU backplates are more common than RGB GPU fans. Using an AIO and vertical GPU set-up, you're potentially hiding the visually interesting parts of your system.
NR200P come with both the vented and glass panels, 2x120mm fans and a PCI riser for vertical mount. The non-P has 1x120mm and 1x92mm fans, vented panels and no riser
Slept on it, think I might go with the vented panel option, and get noctua fans and whatever the best CPU cooler you can fit inside. I care more about a cooler case than what it looks like. Probably get a black case instead as well lol.
