I am having the same problem with these drivers as I did with the previous. You cant cleanly uninstall them to install the new ones.
I did a fresh install to fix this last time. So I am getting this issue on a clean fresh windows install.
At the moment it seems to update the drivers I need to do a clean install of windows as well.
The process goes like this:
1. Try to remove drivers. Get a successfully uninstalled message, but drivers still present in add/remove and folders still in windows. Nothing removed. Run it again and same successfully message but everything still present.
2. Reboot. Nothing changed.
3. Manually remove AMD folders from windows and remove the now orphaned AMD drivers icon from add/remove programs.
4. Run new drivers install and get a failed to install message account exists or some such nonsense.
This is what happened last time. And I ended up doing a clean install to fix it.
WTF AMD...
I managed to reinstall the old drivers which thankfully install successfully.
Then I did an over the top install of the new drivers which also went through successfully.
Feels dirty to do it this way tho. I always uninstall old drivers before install new ones...
Via
this I found this:
Potential Errors and Solutions
Provided below are the solutions to potential errors that may be encountered during the chipset driver install/uninstall process:
- “Error 1720” – This error occurs when there are two Windows MSI installer processes running concurrently. The Windows MSI handler only supports one install at a time, it can be resolved by closing the other MSI installer process within the Task Manager.
- “Error 1316” – This error commonly occurs when anti-virus software other than Windows Defender block the chipset driver installation, as the driver modifies critical system components. Please temporarily disable the anti-virus software and try the installation again. Another possible solution to resolve error 1316 is to clear the system Temp folder before installing the chipset drivers. This can be done by running the Windows Disk Cleanup utility, for how-to instructions please refer to this Microsoft article.
- “Error opening the installation log file” – This is a known Windows OS issue. To work around this problem, please refer to this Microsoft article.
My issue was the 1316 I believe.
I just noticed it says
other than Windows Defender... I'm not running a third party antivirus.
