- 18 May 2010
Right guys the TG panel fits only just, with the Scythe Mugen 5 cooler with 2 fans in push pull.
check here
https://share.icloud.com/photos/0PufkXnUOWUMbmJ_uSwqqIANQ
Ok this is interesting, is this your build? Very nice if so, loving the GPU deshrouded look
Did you do anything to get the Mugen to fit or did you just install and pray, what kind of gap are we talking to the glass is it touching or is their space there?
Must admit I'm a tad confused because tech testers clearly showed the Evo 212 not allowing the glass to shut
Edit - Ah ok its 154.5mm tall so 1.5mm taller than CM's recommend spec, this probably the best 120mm cooler that'll fit with the TG panel if it is a straight drop in and it doesn't touch the glass
