No, I currently have a Samsung S24D590, 60hz with a TFT PLS screen. I want a new monitor and I don't know which one to choose between the U2719D and the S2721DGF. Almost the same price, that's what confuses me!If you're tempted by this monitor there's nothing stopping you running it at 60Hz for now with a view to upping the refresh rate at a later stage if you upgrade your GPU. Just bear in mind you will essentially be paying extra for a high refresh rate that you won't use.
Out of interest, if the U2719D meets you needs why I you considering a new monitor?
I understand that if I take the S2721DGF, I will be paying extra for the higher refresh rate but as I said I really like the design. And you're right, I can change my GPU in the future.
But what justifies the same price for the U2719D? The fine design and the factory calibration at 99% sRGB coverage are not important for me, so is there something else?
That's why comparing the Excel experience is something very important and that's why if I'm sure that there won't be any difference well then I'll take the S2721DGF, otherwise of course I'll take the U2719D
