Indeed there is a fair amount of blockage there. I figured that having the the AIO fans in push, anything I can do to extract the hot air and keep it moving through the case would be a good thing.
When you say it barely moved the needle, is that CPU, GPU and VRM?
I didn't do any proper benchmarking, but I did take a quick look at temps with and without the fan. It wasn't having any dramatic effect; CPU was in the high 60's and case temp around 50 at load either way. If I did a proper test maybe I'd have found a few degrees of difference.
I'm not that fussed when it comes to temps. I'll run HWMonitor in the background, play some games, take a look at max values. If I'm happy with those and the system was sufficiently quiet, then job done.
Am very curious though to try and deshroud the gpu and smack the p12s straight to the heatsink and run them as exhaust.
