Gigabyte X570 Aorus Master Owners
2 Apr 2007
Whitley Bay
Just to let you guys know.
Realtek LAN driver
(Note) Win10 ver.1903 supported.
[1‎0.32.1206.2018]
4‎.83 MB
2‎019/06/13
This driver that is on GigabyteUKs page for the Realtek 2.5 NIC. You will get blue/green screens on the latest windows 10 insider previews when launching certain apps which use tcpip.sys
I was pulling my hair out and rolled back a revision, waited a month or so. Went to the latest build same issue. So you can be certain this driver from 2019 is no longer supported by Windows.
Download the latest driver from here.
https://www.realtek.com/en/componen...0-1000m-gigabit-ethernet-pci-express-software
- Win10 Auto Installation Program (SId:1152921505691095063) 10.043 2020/08/28 10 MB
28 Nov 2011
Realtek LAN driver
[1‎0.32.1206.2018]
4‎.83 MB
2‎019/06/13
Never use the drivers from the GB page. Waaaaaay out of date
23 Sep 2006
I have the x570 aorus pro mini itx and updated to f21 today and have had to roll back to f11, which i was on previously. It wouldnt boot again after any sort of reboot, either shutdown or restart. It would just power up but not post, and just sat there with fans at max etc. Had to pull power, and get it to reset BIOS, then it would work once and boot into windows but then just fail again on next reboot. Rolled back to F11 about 30 mins ago and everything back to normal. Very strange.
28 Nov 2011
I had this issue once the other night in my Elite in F20. Was weird.
Shut machine down, thought it was powered off. Heard fans, nothing in screen. Hard reset with the power button, CMOS reset screen. Loaded BIOS settings again and it's been fine since?
Weird eh?
2 Jul 2016
Realtek LAN driver
[1‎0.32.1206.2018]
4‎.83 MB
2‎019/06/13
Wonder if this might be the cause of the blue screens I have been having on my new build
090120-15250-01.dmp 01/09/2020 00:09:57 SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff804`5b43185f ffff9f00`864d9920 00000000`00000000 ntoskrnl.exe ntoskrnl.exe+3ddf40 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 10.0.19041.450 (WinBuild.160101.0800) x64 ntoskrnl.exe+3ddf40
Had a few crashes related to ntoskrnl.exe
2 Apr 2007
Whitley Bay
Could have been! They really need to remove that old driver set off the page.
Btw im using F30a and i'm finally able to get 3733mhz ram again at CL16 stable without any crashing.
Seems that AMD AGESA ComboV2 1.0.8.1 offers better stability for overclocking RAM
2 Jul 2016
Havent had a crash since I installed that driver, I do seem to keep losing my connection every now and then though which requires a restart to get working again.
6 Jun 2009
No Mans Land
OP
6 Aug 2009
I’m thinking of buying this board but came across this thread and quite a few people having problems with it.
https://hardforum.com/threads/gigab...nt-power-on-temporary-solution.1993194/page-6
Anyone here suffering the same problems as I really like the board and I pretty much always buy Gigabyte boards. But if it’s problematic I’ll have to go for something else?
Been perfect for me, running cool and stable with 32GB 3600MHz C14 RAM at XMP. Best motherboard I've owned with regular BIOS updates too.
22 Sep 2020
Just moved from F20 to F30 without issue preparing to drop a Zen3 in. The only issues I have had are of my own making like the ultra fast booting and not working out how to get back into Bios... sorted now.
