I'll get some pics of the desk, the filters and exhaust, and PCI passthroughs when done. If I'm really good you may even get some of the scratch build etc.
What direction are u running it, and doesnt yours make this annoying sound ? Mine was from the picture right side was inlet, or did you swap out the direction of it before installation ?
Made a video to send to the seller, to perhaps get a replacement or refund this thing is way too loud. Tried it the other way around but it only works one way, other way and without flow it`just flashes "warning" without any info.
Does anyone know any similar flow sensors without the impeller and just pressure sensors on each side ?
aquacomputer ones are way too expensive 50€ and 70€ also they have impellers not pressure sensors, so the danger of having the same problem with noise. If I wanted to pay 100€ id buy the aquaero 6LT and monitor water temps that way.
I didn't realise people got into custom loops as a cheap and cost effective solution
The NEXT flow sensor is impeller, but I don't doubt it'll be effective. If you just want temperature only, there's some cheaper fan control solutions that ship with ambient sensors and in-line 10ks are £3-£10.
For me the NEXT looks like a great bit of kit at £69.
Other than that, just go buy some other cheap tat and roll the dice mate. You'll find something eventually.
