- 1 May 2013
- M28
Preorder up on OCUK.
can't see it, not under Oculus menus or search
Has anyone played Tetris? I've heard it's amazing
It's great, but the graphics are more cut down and blurrier than the PC version. If you want portable, go for the Quest version, otherwise go for PC and play via link. I bought both versions in the end as there was a special offer on the Epic store.
How do you think it will look on the quest 2
I know it's too early to say but is the elite strap likely to be better than a deluxe audio strap?
Comfort, probably, but there's no audio solution. However as the strap is designed to be detachable it's almost certain there'll be 3rd party straps with audio, or audio add-ons for the deluxe strap.
Only thing is that the DAS is black.Ive not bothered with the strap. I messed about with two different straps on the quest 1 and ended up buying one from China. It wasn't that great - and you can't lie back with it because the adjustment knob makes it uncomfortable to lie back on. Will see how the standard one fares.
Any info about FOV?
