That guys Zotac is dead now as well
If you set a custom fan curve do you lose the 0% fan mode when idle?
I can't set mine lower, than 55% for some reason. Using msi afterburner.ATM I do, It wont let me run anything under 30% with a custom fan curve. I can set it but it wont do less.
If that is specific to my card, or a general 3080 thing, I don't know.
pushing a cheap pcb to its limit RIP.That guys Zotac is dead now as well
Zotac trinity, rage 2 and black ops 3 have both crashed.. Might be the card not sureWhat card Josh ?
Zotac trinity, rage 2 and black ops 3 have both crashed.. Might be the card not sure![]()
Oh dear, clock your card back 50mhz and let me know how you get on, I've heard a few cases of MSI and Zotacs crashing at stock clocks, Mines ok but RGB is kaput, Sending back to retailer if Zotac don't fix it within the next 9 days.
Should be OK, I hear Zotac are preparing a download of capacitors and chokes to update the PCB to bring it up to spec.
I think it was just the games.. Black ops 3 zombies did crash before on my rx 5700 xt but never in rage 2. Been running a metro last light benchmark for 30 mins (1440p, max settings, 99% gpu usage) and haven't ran into any issues.. 65c max with 70% fan speed (it's actually very quiet at 70%, custom fan curve)Oh dear, clock your card back 50mhz and let me know how you get on, I've heard a few cases of MSI and Zotacs crashing at stock clocks, Mines ok but RGB is kaput, Sending back to retailer if Zotac don't fix it within the next 9 days.
Different persons gpuits only the RGB, not the whole card![]()
Different persons gpu![]()
you replied to willhub who quoted a Reddit post in which the RGB is only showing red, no dead card
Correct I didyou replied to willhub who quoted a Reddit post in which the RGB is only showing red, no dead card
There's a bug in Firestorm that borks rgb. I'd really recommend people don't dick around with the rgb until they fix that.Quite a few complaints coming through on to zotac subreddit around the rgb stopping, crashes and the fans acting strange (one fan stopping, one fan pegged at 100% and so on).
Some might be that spectra software they have.
