- 18 Sep 2020
Hi, thanks for your explanation. I have corsair r750i or rm. I was on their website and the only cable with 4+4 wad like you said CPU cable. I am clueless as to what cable to get and it needs to be compatible with my PSU. Could you plz help.
I suspect you mean RM750i, which will be fine for the 3080. The sockets in question you will use are the red ones 1,2,3 in the pic.
You want the 6+2 PCI-E cables x2 and plug the 8 pin ends into two of those sockets (1,2or3 in the pic). The other ends will likely have two 6+2 connectors, so you should end up with 4x 6+2 connectors to play with, just use the two main ones (not the extra ones). You can get some sleeved cable extensions if you want it to look good.
The remaining socket in that block of three will have your CPU power cable in, which will be a 4+4 at the end. This allows support motherboards with a 4pin or 8pin power socket.
