Hope they have fixed all the security issues, was like they threw security under the bus to get single thread performance.
The 2 key metrics for me are single thread performance and power efficiency (as that also relates to heat). Cores are nice but not critical.
Even AMD in their last presentation have now admitted single threaded performance is important, now they have finally caught up on that, they are open about it.
If Intel e.g. did a 30% IPC boost with no power increase or even a power drop, they of course would be in led again on the desktop even if its capped to 8 cores. Remember not everyone is an encoder. Most people are generic desktop users or gamers.
The consoles are 8/16 cpu's so for most situations 8/16 will be the point where after extra cores give you diminishing returns in games. Unless you are multitasking at same time such as streaming and gaming on one PC.
Any cpu's with more than 8 cores to me are halo products, so I wait and see what intel can do, we need good competition, if they go back in the lead, then these new ryzen chips will go down in price, think on that.
Does AMD have an equivalent bounty program to pay researchers to find their security flaws?Hope they have fixed all the security issues, was like they threw security under the bus to get single thread performance.
Yeah I think I meant that intel pay for someone to find the intel flaws. Not sure if AMD do the same.Does AMD have an equivalent bounty program to pay researchers to find their security flaws?
I think AMD has security issues as well - as I recall the search for these focussed mostly on intel as they pay you to find them.
AMD has missed it's taste of bad press on this issue - much like bumblebees and wasps... they both sting but everyone hates on wasps despite being important in pest control for crops...
Also it's not dissimilar to Trump's desire to not test for COVID - more testing on intel shows more security flaws. At least we know about them!
Intel Rocket Lake CPU Rumors: 5 GHz All Core OC, Huge Uplift in Gaming & AVX-512 Perf But Runs Hot, Full Support on Z490 While B560 Gets Memory Overclock
- Supports PCI-e Gen 4.0 Protocol
- AVX512 can achieve greater performance (But it runs really hot even under 8 cores and leads to higher power consumption)
- Both L1 cache & L2 cache sizes have increased. 10th generation core is L1 32KB / L2 256KB while 11th generation core is L1 48KB / L2 512KB.
- Summary: Although the 11th generation Core is 14nm, there is a real change in performance.
- Architecture has improved gaming performance. It is a lot stronger than the 10th generation Core, but it is still a long way from AMD in Cinebench R20 and R15 (Multi-threading) because core count is still only 8 cores while AMD has up to 16 cores.
- It is very easy to run overclock all cores to 5 GHz.
- Drop-in compatibility with Z490 motherboards with PCIe 4.0 support on boards that have the necessary hardware integration. Z490 VRMs are sufficient to overclock the 11th generation.
https://wccftech.com/intel-rocket-l...ll-core-oc-huge-uplift-in-gaming-performance/
I will tell you - don't hurry with the purchases - let's wait and see what will happen in March-April next year.
It is very easy to run overclock all cores to 5 GHz. < That almost certainly isnt true, if it was, then the cpus would all have it as turbo clock.
Intel are going down the wrong path, AVX512 should be dead, performance at the cost of more power and heat shouldnt be a consideration in 2020.
Are you referring to Threadripper and other power hungry HEDT chips?performance at the cost of more power and heat shouldnt be a consideration in 2020.
AMD is going the wrong route, too, no 45 or 54 watt CPUs, only one 65-watt 6-core and everything else up is 105-watt.
Yeah I wish they had more low end stuff. Need a sub 50 watt cpu.
They exist, they're just not the flagship products.Yeah I wish they had more low end stuff. Need a sub 50 watt cpu.
