Well they might be cheaper, they are using older/slower memory and smaller memory bus, giving them substantially less memory bandwidth. That means they can keep prices under control, it also means they need to find a way to reduce memory bandwidth usage otherwise they're going to starve the GPU of data and have pretty severe bottleneck issues. If they've successfully done that kind of remains to be seen yet.
That's a big gamble, to add more memory that will have no benefit just to sell cards to people that think more GB's = more speed. But then introducing bottlenecks because of that and potentially struggling to keep up in benchmarks where it actually matters, is where it could end in tears. Especially if their solution to low memory bandwidth (infinity cache) turns out to be something that requires a lot of per game optimization to work well, and their reputation for not really the best drivers. I mean we'll have to see it's too much speculation at this point.
Yep. GDDR6 is slower than 6x, it runs at about 16Gbps, where as 6x runs at about 19-20Gbps. One thing you need with high end GPUs which are very fast is you need to be able to serve them with data fast enough to keep them busy, otherwise they get bottlenecked by the memory. That total speed is the memory bandwidth and that is a product of 2 things, the memory speed 16Gbps vs 19Gbps, and the memory bus (the width of the data transfer from vRAM to the GPU) which is 256bit vs 320bit. The memory bandwidth is these 2 multiplied together, with AMD opting for both slower memory and smaller bus width it means their overall memory bandwidth is a lot smaller, about 512GB/sec compared to 760GB/sec on the 3080
I agree. It’s the benchmarks that count.
It AMD are matching or succeeding Nvidia with a higher VRAM limit.. then surely they are the no brainer
