It depends what's on the board already, but you can't know that without powering it on. I imagine it would be safest to flash it from a USB stick first.Will a 5000 series chip work straight out the box in my msi mortar b550 or will I have to find a usb drive to load a driver onto and flash the motherboard before I install the chip?
Did the watch the PCB breakdown? It mentions nothing about LN2 when covering the 2 x 8 pins
No its about powering the PCIe devices via the board, not needed for most people but its there for those who get closer to those limits
When you say 'safest', nothing bad happens if you powerup with a 5000 series chip, and it isn't supported. Then you can do the USB flash?It depends what's on the board already, but you can't know that without powering it on. I imagine it would be safest to flash it from a USB stick first.
What happens if you do it after discovering old BIOS doesn't support?Flash the BIOS (that supports Zen3) prior to installing the CPU.
I'm not wrong, he mentioned nothing of LN2.You are both wrong. I suggest you watch his later video where he corrects himself:
A single 8 pin CPU power connector can provide 384w, for 99% of people this is more than enough. If you plan on going hard with LN2 or 'extreme' overclocking, plug in the extra 8 (or 4) pin connector if it's available.
Indeed, but is there any reason why you can't do that with the CPU installed, system fully built?
The PCIe power was incorrect as shown on your video but the extra 8 pin could be used by GPUs if required
Oh yeh, sorry, me being a spongo and not realising GPUs are PCI-EThere's a video of an engineer from MSI explaining that the two 8 pin connectors are for the CPU only. Buildzoid was wrong in his video you linked, he corrects himself in the video I posted.
The additional 8 pin CPU power cable, does NOT provide power to the PCI-E slots.
I have an X570 MEG Unify but not sure if the board comes with the latest BIOSIndeed, but is there any reason why you can't do that with the CPU installed, system fully built?
Oh yeh, sorry, me being a spongo and not realising GPUs are PCI-E.
At least Buildzoid said he was wrong instead of coming up with excuses like most people would do
Version 7C35vA73 (Beta version) 2020-09-29
"Updated AMD AGESA ComboAm4v2PI 1.1.0.0"
It might not so have followed that video and added the latest BIOS to USB just in case. I also contacted MSI asking them if the MEG Unify shipped with the latest BIOS (purchased last week) I might aswell flash to the latest BIOS before connecting anything
Thanks for the vid Gee
Tomahawk's manual says it has to be formatted as FAT32, and by default windows won't let you format anything larger than 32GB as FAT32(it can still be done, but only with external tools).Ive got to wait until I strip this system. I do have a new PSU, but cant really be bothered trying to rig it up to my Tomahawk on the desk just to flash the bios.
Will any USB work, or does it need to be a small capacity one? Think I read issue with using 32gb etc
Similar position as you. My system now is all rigged up and CBA unplugging things just to flash the BIOS. Next week before putting the CPU in i'll flash it beforeIve got to wait until I strip this system. I do have a new PSU, but cant really be bothered trying to rig it up to my Tomahawk on the desk just to flash the bios.
