Nope,It was actual order ready to dispatch,if you look it says priority delivery tomorrow by DPD.Pre orders is I’m seeing
which site? the one nvidia directs to?The 3080 FE were relatively easy to get on that same site yesterday though
way more.Plenty of 3070 founders edition cards on that famous auction site, seems more cards were available for this launch.
I can relateI was so annoyed not getting the 3080 / 3090 FE I ending up buying MSI GeForce RTX 3090 Ventus 3X 24GB OC GPU.
I kept telling myself to wait as long as it takes for the FE but I lack discipline
Now it's dispatched I'm kind of regretting it, I just can't decide what to do, I'm getting annoyed with the 1080ti and got a week off work to play with it...might flip a coin on whether to return it.
I just can't justify the £1550 price tag and can't get my mind off the FE
It's really crazy that the best 3080/3090 is the cheapest!!! Really damn nuts![]()
A lot of people reporting coil whine on the founders edition models, I hope it's not a widespread isssue.Ok so tested the fe card tonight compared to the palit I had before.
Performance wise there about the same, the FE did win in each test but not by much. It also ran about 6-7 degrees hotter then the palit. Looks wise it’s miles ahead and feels very well made.
Only 2 bad points are it has noticeable coil wine where the palit had none and the 12 pin adapter is ugly. It sticks out like a sore thumb.
Aren't you considering the 6900XT?
It tends to go after awhile.A lot of people reporting coil whine on the founders edition models, I hope it's not a widespread isssue.
Ok thanks, good to know.It tends to go after awhile.
