Got mine on the 2nd of October and over the last couple of days I've been getting popping sounds. Not too loud but annoying Its happening on a new monitor. Last week I did leave the brightness on 100 and white screen and it got super duper hot, feel the heat from several inches away hot. Maybe that has something to do with it.
Does anyone know what the return dates for samsung are, I'm coming very close to 1 month now and not sure what to do.
Seeing they're also still sometimes sold out, I may not get another one straight away.
For running info; I've mainly been using it on 5120x1440 and sometimes PIP split screen. Playing Doom Eternal on max settings im getting around 180 FPS on a Zephyrus Duo. CSGO been getting a over 240FPS. They all look very good, however I mainly use the screen for reading/research. Also I do not know If I have all the settings configured correctly, bit of a computing noob.
I've yet to see someone (sure there are) say they have not got the cracking sound, I have it right now. If you pinch the sides and/or put pressure on the back panels (without touching the screen obviously) you can replicate this noise - in this instance, it leaves me to believe its a heat issue with the plastic expanding. Conversely, I also get the cracking from around the power switch. I also have a slight buzzing sound coming from the power switch area, and when I have the power lead in and the monitor turned off I hear a "Tick tick tick" sound. I still have 7 days to decide if I want to return this, I'm not sure. The picture is amazing and the cracking sound stops after 40 minutes! Its strange, I use monitor bright to turn down the brightness quickly and the more the brightness is turned down, the more the monitor cracks. If the monitor cracks when its at max res after playing games for hours, then I would return, otherwise I tend to believe this is just a heat/plastic issue thats not worthy of a return. *shrugs*
