 - 27 Apr 2014
Why would my 3800X degrade. Hell this week I owned 3600XT/3800XT/5800X.Did your 3800x degrade?
I know you thought my CPU voltage was too high on 3800X but that was just not true at all.
Dude owns a Ryzen and never knew how they work.That's [email protected]+
Anything is possible,there are always bad CPU's.For instance my 3800XT I had to return it because it would crash at idle/desktop/youtube no load and very common problem. I have not had any reduction across any Ryzen CPU I owned and in a matter of fact with BIOS updates they only gotten better.I degraded at stock cores and just the RAM/IF overclocked.
Putting our differences aside, I thought it was 4x 8 (1R) or 2x 16 (2R) for optimal memory perf?Impressive. I’m thinking of building a master race gaming PC around 5000 chip.
I’m thinking a tuned 5800X, 4x8Gb of 2Rx8 and a 6900XT might be the most glorious route.
Glad you had success, Well it is a benchmark ,so I do not see the difference you see between scores . there pretty much identical.If you did all core overclock alone you would get higher multi lower single.There are settings in BIOS you can change.
AS far as idle clocks go,you can change your power plan,if you want lower idle clocks.
You can set whatever you want and check stability for higher scores even if that is what you want. First off there are two different areas in all BIOS for PBO stuff.
In the AMD overclocking section ,go to PBO and set your AMD curve optimizer up- this will give you normal boost clock EG:5800X boost to 4850Mhz
In this section you can add up to 200Mhz it is the same for all motherboards EG: 4850Mhz+200Mhz=5050Mhz
If you want higher CPU boost clocks then you need to goto the second area for PBO settings
Advanced CPU Configuration set your PBO boost higher than 200Mhz like in the first section on MSI motherboards you can go as high as 500Mhz
To get 5100Mhz then set PBO here to 250Mhz
So 4850Mhz+250Mhz= 5100Mhz
save and test.
I also made a spreadsheet with how much voltage offset there is with a setting in BIOS so you can use that for high scores with more voltage and clocks..Now I did not do every setting ,that would be impossible. going 1/2/3/4/ at +- anyway enjoy
https://docs.google.com/spreadsheet...QvVSKyfD4DQghgUHb46-VIIzl3BQvX-hYt0D4/pubhtml
Yes you are missing something. All AMD Ryzen CPU's are smart and they work a little different.My settings can be copied as a guide. You know this is overclocking a CPU they behave different. You need to find your setting. Out of the box the 5800X boost to 4850Mhz .SO if you copied my settings ,which is negative by the way ,so your CPU may not get enough voltage so use my chartMine refuses to run or stay stable at ANYTHING over +50Mhz Boost. Even with identical settings. So it seems not all chips can do this unless I'm missing something..
Well it has been explained many time on how AMD works but this is it in a nutshell.I don't yet. Is that 1.5v what it's using when hitting max boost clock? Just getting an idea of how much vcore ryzen uses. Guessing a fair bit for higher clocks hence temp issues when using dark hero with DOS.
VF-curve test offset per core pick a voltage and start clocking. If you want a magic overclock AMD already does that for you.
 I was only mentioning mine isnt doing what your would with those boost settings alone, you didnt mention voltages previously so I will take a look at those now with reference to your chart, thank you !LOL I trying to help you,you think that is mad what I wrote,grow a backbone
I am a strange guy sitting in his basement playing video games for the last 20 years.
