Oh god yeah I remember. It's annoying because as you say AC:V should run better on SX by all accounts, but as it turns out both versions are sub par with tearing and choppy frameratesI fear that having VRR will be used as a crutch despite it being an uncommon feature on most users tv's.
I see the PS5 thread is page after page of discussions about tracking numbers and courier choices today. Been there, done that etc..![]()
Next it will be comments on the size.
I'm not saying that, the hardware on paper is more powerful that is a fact. I think the car analogy is perhaps wrong here. I'd be willing to bet that an accomplished dev say Naughty Dog can and will make much better looking games (and performance) than a lesser dev on Xbox. The hardware advantage doesn't count for anything if you have lazy or not as capable people developing for it.
I'm not sure having a more powerful console that is performing worse is really something to be happy about regardless.
Of course not, but the point here is that developers only got the proper Series X and S dev kits in June, so these reports about the PS5 blowing the Xbox out of the water a week after the console have been released are premature at best. But what many developers are saying is that from what they've been looking at, the stuff that the Xbox can do is very exciting, and that's without even fully exploring RDNA2.
There's no doubt that they're both very powerful consoles. Owning either one is going to bring some very exciting things to the table; I'm just more excited about what they'll be able to do with the Xbox because I won't be getting a PS5 simply because I have no need for two consoles, a Switch, and a PC. It doesn't matter to me which does things better, but therotically it should be Xbox given the raw power and ability.
Dolby app has 30% off. Now under a tenner. Good timing.
.... And Forza Horizon 4 now showing Quick Resume enabled!
Dpad clip
other 2 controllers (the stacked ones)
360 connected to PC, and below it ps4.
https://streamable.com/c2c2ra
I think the click-y dpad is normal (for the series s). I'm sure in this thread or another me and a few others mentioned it and others all had the same issue so it's by design. Just takes some getting used to!
rp2000
Dolby App, I thought that was free.
You talking about the dolby access app that is required if you bitstream atmos?
Not certain as I only have the white series s one. I would imagine they are the same as it's just colour differences.Do the series X and standalone controllers not have the issue then?
But would wait till an elite controller and a series X owner to answer as I'm not an expert!
rp2000
Digital Foundry have created a PC like following with consoles with all their pausing and zooming in on the pixels.
Like, if it takes a 300% cropped zoom to show off the difference in a texture or reflection, it can't be a hugely significant difference.
