- 24 Mar 2011
- Kent
Yeah the whirring is slightly annoying but the coil whine is much worse.The whirring is what I was talking about. Sounds like a drone to me. I'll have to get used to that as it is normal by the sound of it.
It annoys me - but at least I know it is normal.
Out of question, if your PS5 on a power strip? Might be worth trying to plug it directly into the wall to see if it makes any difference - I have sometimes interference can cause whine.
I'll try the console plugged into the wall directly, it is on a power strip.Good thing with remote play, no display needed!
