- 18 Feb 2007
- London
I purchased the shock blue controller recently, it sure is nice with the blue/white shell.
Oh just noticed your location, our paths may cross in store reach![]()
Pistols at dawn!Fight Fight Fight![]()
I read you can change the tension? On the top left stick was the review I watched...Just got my Elite V2 replacement from Microsoft. Unsurprisingly the hardware design flaws are still glaring but at least the left stick has less free play, even if the right stick and dpad are still atrocious.
If the buttons work correctly I’ll just keep this one and fix the hardware design flaws myself.
I’ll shut up thenThe free play has no relation to the tension.
For me its absolutely fine and am very happy with my purchase, my complaint is really the controller been of poor quality. Vesperia runs better than on my ps4 pro for reference. The zen2 really showing its class vs the mobile jaguar cpu. Vesperia load times also match my pc, again much better than ps4 pro. The value is extremely good in my opinion. What you getting for £250 in todays market is a minor miracle.
It is slightly less width than my xbox360 slim, but the depth is noticeably less (doesnt go back as far).
Also my cabling is much tidier now, previously I had a bulky power cable at back of the 360, a bulky vga cable, which also had sound cable split offs to feed sound to PC, all this is out of my spider web of cables now.
I’ll shut up then![]()
Got you, I’m now having second thoughts about the Elite V2 so may return it and get a decent wireless keyboard & mouse for FPSThe tension only impacts the sticks once the springs start to resist. The free play is the distance the stick can move before the springs activate.
2-3 mm total play like I had on my Elite V1 is normal, but this is 6 mm.
At least the face buttons work now so I can mod this controller to fix the dpad and sticks.
Dirt 5 is running at 120fps on maximum image quality mode on my 1440p monitor apparently.
I didn't expect that, I'd read that the console would down res the 4k version of the game and run at 60fps.
Hope that is a sign of things to come.
Hi which monitor are you using with the Xbox? I'm on the hunt for a monitor that'll work with my Series X and PS5.Ooh, Gears 5 runs at 120hz at 1440p as well. I thought it would be 4k downscaled at 60hz?
Thanks for the quick reply, I'd seen that monitor recommended but I believe it's only got one HDMI input and I'm lazy and clumsyHP Omen 27i. No hdr but 165hz and vrr over dp and hdmi.
Some of the monitors I've looked at (IE Dell S3220DGF, Samsung G7 and Benq EX2780Q) will accept a 4k signal it's just displayed at 1440p and I'd be able to run 1080/1440p @ 120hz for Xbox. But your correct, if Sony updated the PS5 to support 1440p natively it would help.It’s a shame that the PS5 doesn’t support 1440p as that limits your choices.
Thanks for the quick reply, I'd seen that monitor recommended but I believe it's only got one HDMI input and I'm lazy and clumsy![]()
