feels per second?![]()
So the CSV mem settings does nothing for me but the exe change for AMD cpu helps
First part with it enabled, all cores used properly. Last part is with original exe.
FPS wise running around the same street after load
- AMD exe = 75-80
- original exe = 70-75
Below is with original exe at a different location
With slightly tweaked DF settings
- DLSS performance = 75-80
- DLSS balanced = 66-70
- DLSS quality = 57-60 starting to feel really laggy when moving around
And sticking with DLSS quality
RT off = 93-103
RT reflections = 69-73
RT reflections + med lighting = 57-60
RT reflections + shadows + med lighting = 51-54
RT reflections + shadows + psycho lighting = 43-47
I prefer DF tweaked setting using DLSS performance + nvidia sharpening than running with RT off in this game. It's not really a fast paced shooter
