What are temps like as the all core does seem low, should be boosting to around 4.5-4.6 all core at stock.
Temps aren't a problem - never peaks over 55c. I have overkill cooling on it (Alphacool Extreme 280) just so I can run it nice and cool and quiet. I can see individual cores boosting over 4.7, but when its a heavy multi thread test they never get higher than 4-4.1
My C20 scores are the same, single core seems OK, but multi seems on the lower side.
This is what happens during a multicore test of R23, as you can see all the cores hit around 4ghz and don't move any higher. Temperatures are low. Voltages also seem low? I havent changed any of the settings. The BIOS is the latest 'beta' one that enables SAM on the X570 tomahawk.
This is with PBO enabled with manual limits:
PPT 125
TDC 105
EDC 120
MAX OC 200MHz
This way it boosts all cores to 4.4, much higher volts and subsequently temperatures. But should I have to do this? Shouldn’t it be boosting better on all cores without PBO?
roll 6
