Any one know what that display is??Not mine.
It is possibly an old android phone with the pitikapp app. I found the original image by accident with no description etc. Searching for it takes me to Reddit where a similar image (also showing the vertical NR200 with small screen) appears and the user states that that is what they use.Any one know what that display is??
Have managed to find one of these and will be starting a build soon with a gigabyte b550i, gigabyte rtx3070 Eagle oc and 3600 for now. I was tempted to order an Id cooling 224 after seeing the mandm videos and it's available in white. But does anyone know of this will block the top fans using the gigabyte board. Is it worth switching to the msi board instead?
Also switching the fans for p12s should I add the bottom fans and an extra on the cooler?
Any suggestions welcome have lurked on this thread for a while and have been waiting to get my hands on one of these for ages.
The Gigabyte board does have a higher CPU socket location than others. I can't speak for the ID Cooling 224, but the Mugen 5 in my case does allow for 25mm fans to be installed on the top panel. The caveat to this is that I didn't use the protective fan covers and that I also had to slightly bend the fan clip holding the fan on the Mugen 5. If I didn't, it would protrude into the top fan.
I assume also you’ll also be using the TG panel if your worried about seeing your ram.
I’m using the Sythe Mugen 5, others are using smaller top down coolers which work fine as well.
Well that depends where you plan on putting the radiator!Any water coolers that will show ram?
